ZTP
1121 / 0
Uploading a Configuration File
Step 1: Click the   icon in the Action column of a gateway, and then click Config Upload.
Step 2: Click Select a TXT file to upload a configuration file.
Displaying Configuration Detials
Click Config Detail to check the detailed configurations.
Displaying Configuration File List
Click Config File List to check the configuration file list.
