Creating a Tunnel
1819 / 0
Follow the steps below to create a tunnel. Before creating a tunnel, make sure the device is online:
Step 1: Select the device.
Step 2: Click More, and then click Tunnel.
Step 3: Select a tunnel type and click Create Tunnel.
Step 4: When the tunnel is created. Click Open with IP to access the device's eWeb.
