00000JAPAN WiFi
1466 / 0
00000JAPAN WiFi is a free Wi-Fi with no requirement for authentication. When a disaster occurs, it can be quickly enabled and deployed to provide Internet access. This function is applicable only to RGOS devices.
As long as the layer-1 network is enabled, the devices of this network and its sub networks will be turned on as well. When the layer-1 network is disabled, the devices will be turned off.
00000JAPAN WiFi is globally disabled by default. To enable 00000JAPAN WiFi, click  and then click 00000JAPAN WiFi to go to the setting interface. The interface shows the names of all layer-1 networks (root networks) under the current tenant. When the 00000JAPAN WiFi function in the network is enabled, all the devices in the subnetworks will simultaneously enable 00000JAPAN WiFi.
Follow the steps below to enable 00000JAPAN WiFi on your network:
Step 1: Click , and select 00000JAPAN WiFi to enter the management page.
Step 2: Click   in the Action column of the corresponding network name.
Step 3:  Enable the function, select the forward mode (only available for non-apartment scenario), and click OK.
Step 4: When the confirmation prompt appears, click OK.
Step 5: When the "Operation succeeded" prompt appears, click X to close the prompt box and complete the operation.
