Ruijie JaCS V1.4.4 Released on August 26, 2022
2127 / 0
  • The design of the old version is cancelled in the Topology menu. In this new release, the Topology feature supports detecting the topology of downlink devices of an online switch.
The Topology feature also supports diagnosing the operation of online switches under the network group.
The Topology feature also supports generating a report to visually display risks identified in the diagnosis.
  • The Downlink Device List is added on the switch's Details page.
  • Bulk creating VLANs and changing VLAN creation rules are supported.
No.Bug Description
After the S1930 switch goes online, CLI will print the error message: /sbin/maccmng.sh: line 1: arithmetic syntax error
2If Web CLI permission is enabled for an existing admin account, the permission of account can not be disabled.
3When the SSID named “00000JAPAN” is imported, the prompt is improper.
4When a rule is imported to an apartment network, two prompts will be displayed if the position is repeated.
Up to 300 devices can be imported each time. To import more than 300 devices, users need to do it in batches.
APAccount-based policies may fail on some models, such as AP680(CD), where they are disabled by default. In this case, users need to batch apply from the Cloud the web-auth acct-update-interval 1 command to enable those policies.
SSID reverse sync
00000JAPAN WiFi
In the Apartment Scenario, if the device goes offline after 00000JAPAN WIFi is enabled, and then goes online after 00000JAPAN WIFi disabled, Cloud will not re-configure the Wi-Fi settings on device. You need to clear 00000JAPAN WiFi configuration manually.
APIn Non-apartment Scenario, please clear the configuration on devices except AP180 before bring them online; otherwise, the configuration on devices may be conflict with that on Cloud, and the client may not be able to access the Internet.
10
APIn Non-apartment Scenario, if the working mode (bridge mode or routing mode) of AP180 is different from that on Cloud, the client may not be able to access the Internet.
11
TOPOLOGY
  1. Only downlink devices connected to a switch can be detected.
  2. Only APs (excluding MAs) are detected and the topology of the switch is displayed.
12
TOPOLOGY
Uplink ports of below switch models cannot be identified on the Cloud, in which case the topology of uplink ports is not displayed.
Switch models involved include:
XS-S1930J-8GT2SFP, XS-S1930J-8GT2SFP-P,
XS-S1930J-18GT2SFP, XS-S1930J-18GT2SFP-P,
XS-S1930J-48GT4SFP
