Ruijie JaCS V1.5.1 Released on July 31, 2023
3693 / 0
This new release supports displaying the downlink devices of an online gateway (EG5210-JP) in the current network. Also, the security of Ruijie JaCS is improved after high-risk vulnerabilities scanned by software are solved.
Network Topology
The previous network topology only supports displaying the downlink devices (APs) of an online switch in the current network. But in this new release, it can display the downlink devices (including switches and APs) of an online gateway (EG5210-JP) in the current network.
Security Improved
Dynamic vulnerability scanning software (NSFOCUS ICSScan, Nessus and RG-Scan) and static vulnerability scanning software (SCA) are used to scan and fix vulnerabilities to improve the security of Ruijie JaCS.
Changes
Factory Settings becomes an independent tab in Configuration > Settings > AP > Initial Conifg Template > Modify page.
The Web kept freezing occasionally when over ten thousand network groups were created or over ten thousand devices were imported.
SSID reverse sync
00000JAPAN Wi-Fi
10
11
TOPOLOGY
12
TOPOLOGY
Included:
XS-S1930J-48GT4SFP
13
14
CLI Commands
15
WPA3-SAE
16
Device Details-Back Up
Only for apartment networks.
17
Network Management
18
Upgrade Policy
19
Quick Deployment
1. This feature is applicable only to AP180 series access points.
2. Switches only can detect the APs that can access wide area networks.
