Ruijie JaCS V3.1.0 Released on October 12, 2026
300 / 0
1.JaCS V3.1.0 delivers underlying architecture upgrades for multiple platform pages. The existing page functions and interaction logic remain unchanged, so users can continue working as before. Page rendering and loading chains are optimized to significantly improve page access and response speed, delivering a smoother user experience.
2.To improve usability, Radio configuration modification is added under the Network Config > RF Planning menu for hotel-based projects. Users can directly modify and manage Radio-related configurations on this page.
3.The last synchronization time is added on the AP device synchronization detail page. It helps quickly check the timestamp of the AP’s latest configuration sync and assists in judging the device synchronization status.
4. The First Online Time field on the device list page supports ascending/descending sorting, enabling quick filtering devices by their online time.
5. The offline alarm for all network devices supports a customizable offline ratio threshold. Alarms will be triggered only when the proportion of offline devices across the entire network exceeds the configured threshold.
6. JaCS V3.1.0 now supports customizing CPU and memory alarm thresholds for switches and LitePON devices (configuration is only available in the root group and takes effect globally).
7.  Alarm settings can be applied to the root group. Once applied, alarm rules take effect for all projects under it, and newly added projects automatically inherit this alarm configuration — no further setup required.
8. On the Network Config > RF Planning page, the country code and bandwidth configuration of the current project can be applied in bulk to other projects. The configuration will take effect on devices under the target projects once distributed.
9. JaCS V3.1.0 now supports setting an upgrade policy for LitePON devices. With this feature, users can uniformly manage firmware upgrades for these devices, enabling orderly batch version maintenance.
10. When a LitePON device connects to Ruijie JaCS, the system automatically backs up its configuration and retains snapshots for fault recovery and traceability.
11. The alarm list page now supports data export, allowing alarm data to be exported for offline viewing, statistical analysis, and archiving.
12. Project handover and deletion functions have been added to the My Received page. Users can handover or delete projects received under their account.
13. JaCS V3.1.0 now supports bulk import of device information. Device aliases and other details can be updated by importing files, making it easier to maintain large numbers of devices.
Changes
1. The Web CLI button has been moved to the Action column of the device list.
2. Added validation rules for web login passwords. In addition to meeting complexity requirements, passwords cannot contain the keywords "admin" or "ruijie" to enhance account security.
3. Adjust the alert thresholds of CPU and memory usage to 80%
4. JaCS V3.0 is fully compatible with all device features in JaCS V2.0. Please note that JaCS V2.0 will be officially shut down on October 12, 2026.
1. Fixed an issue where the AI assistant was inaccessible.
2. Fixed an issue in the channel scanning radio recommendation module where the displayed power for Radio 1 (2.4 GHz band) was stuck at 100 and did not update dynamically with the calculation results.
3. Modified the task queue mechanism to fix the following issues: devices remaining in "upgrading" status for an extended period after firmware upgrades; slow cloud-side synchronization when device information changes.
4. Fixed an issue that the link in alarm notification emails redirected to an incorrect page. Now, clicking the URL within the email will open the corresponding target page normally.
SSID reverse sync
00000JAPAN Wi-Fi
10
11
TOPOLOGY
12
TOPOLOGY
Included:
XS-S1930J-48GT4SFP
13
14
CLI Commands
15
WPA3-SAE
16
Device Details-Back Up
Only for apartment networks.
17
Network Management
18
Upgrade Policy
19
RG-HS2310-16GH2GT1XS
20
Project
21
ZTP
Only for RG-EG5210-JP gateway and XS-S1620J series switches.
22
XS-S1620J configuration file rule
Refers to Managing ZTP configuration file
23
AI Troubleshooting
Currently supports only the AP180 and S1930J series
