Ruijie JaCS V3.0.1 Released on July 1, 2026
881 / 0
1. JaCS V3.0 refactors the pages for OLT, ONU, and GHN devices, with no impact on interaction or functionality. For detailed feature differences between JaCS_V2 and JaCS_V3, please refer to: https://cdn-japan.ruijienetworks.com/service/api/download/userguide/JaCSV2V3_en.pdf
2. Add the 'First Online Time' field to the device list.
3. Ruijie JaCS has supports MT-3001 device, which shares the same specifications as the MT-3002.
4. Add an entry on JaCS V2.0 to switch to JaCS V3.0.
5. Ruijie JaCS V2.0 will be officially discontinued on September 20, 2026.
1) Seamless Transition: Log in with your current account and password to access V3.0 automatically. All data (tenants, devices, and network configs) is fully interoperable and safely retained.
2) Upgraded Features: V3.0 improves overall usability and upgrades core functions like  Independent Living Care, AI Troubleshooting, and Dr.R Assistant.
3) Easy Rollback: Before the final shutdown, a one-click switch is available on the new page to revert to V2.0, helping you adapt smoothly.
For any operational issues, please reach out to our Technical Support.
5. Dr.R Assistant (Beta): Improved AI Q&A feature. Now supported in JaCS_V3.0, you can use AI to send basic commands to AP180 series devices.
6. The AI troubleshooting feature supports the RG-AP180-AC/PE(V4) devices
Changes
1. Updated the roaming feature to only allow configuration under Level 1 projects or groups.
2. The Upgrade and Upgrade All buttons will not be displayed for sub-accounts.
3. JaCS V3.0 is fully compatible with all device features in JaCS V2.0. Please note that JaCS V2.0 will be officially shut down on September 20, 2026.
1. Fixed an issue where the AI assistant was inaccessible.
SSID reverse sync
00000JAPAN Wi-Fi
10
11
TOPOLOGY
12
TOPOLOGY
Included:
XS-S1930J-48GT4SFP
13
14
CLI Commands
15
WPA3-SAE
16
Device Details-Back Up
Only for apartment networks.
17
Network Management
18
Upgrade Policy
19
RG-HS2310-16GH2GT1XS
20
Project
21
ZTP
Only for RG-EG5210-JP gateway and XS-S1620J series switches.
22
XS-S1620J configuration file rule
Refers to Managing ZTP configuration file
         23AI Troubleshooting
Currently supports only the AP180 and S1930J series devices.
