Ruijie JaCS V3.1.1 Released on October 29, 2026
176 / 0
Changes
1. You can search for a device in the search box via its MAC address in the format xx:xx:xx:xx:xx:xx. For example, after entering 10:5f:02:f9:62:68, you can find the device with MAC 105f.02f9.6268.
 2. The alarm export function supports exporting filtered results based on current search criteria. The interaction is consistent with that of import tasks.
3. Map view under Home > All Projects > My Created is optimized to support up to 10,000 projects.
4. In addition to the global CPU and memory alarm configuration, personalized alarm configuration is supported. When the global configuration enables the alarm but the personalized configuration disables it, the personalized configuration prevails.
5. WeChat notification options are hidden in alarm settings.
1. Fixed an issue where the time axis of the traffic timeline on the device details page did not match the local time zone.
2. Fixed an issue that RX alarms of LitePON devices could not be cleared.
3. Fixed an issue where offline alarms for LitePON devices were not cleared when the devices came back online after being offline for more than 30 minutes. Historical uncleared alarms will also be processed in bulk, so you may receive multiple device-offline alarm clearance notification emails at that time.
4.  Fixed an issue where the upgrade policy did not take effect when "00" was selected as the number of minutes in the upgrade policy.
SSID reverse sync
The Cloud does not support SSIDs containing special characters. If set on end devices, such SSIDs will fail to be delivered, after synchronization, by the Cloud.
00000JAPAN Wi-Fi
In the Apartment Scenario, if the device goes offline after 00000JAPAN Wi-Fi is enabled, and then goes online after 00000JAPAN Wi-Fi is disabled, Cloud will not re-configure the Wi-Fi settings on device. You need to clear 00000JAPAN Wi-Fi configuration manually.
In Non-apartment Scenario, please clear the configuration on devices except AP180 before bringing them online; otherwise, the configuration on devices may conflict with that on Cloud, and the client may not be able to access the Internet.
10
11
TOPOLOGY
2. Only EG5210-JP, XS-S1930J series switches and APs can be displayed in the topology.
12
TOPOLOGY
Included:
XS-S1930J-48GT4SFP
13
14
CLI Commands
15
WPA3-SAE
16
Device Details-Back Up
Only for apartment networks.
17
Network Management
18
Upgrade Policy
1. Not supported in sub accounts and networks shared by other networks.
19
RG-HS2310-16GH2GT1XS
20
Project
21
ZTP
Only for RG-EG5210-JP gateway and XS-S1620J series switches.
22
XS-S1620J configuration file rule
Refer to Managing ZTP configuration file
23
AI Troubleshooting
Currently supports only the AP180 and S1930J series
24
Each tenant is limited to adding up to 2000 new devices per day.
