Resetting Password
7277 / 0
If you forget your password, you can follow the steps below to reset it:
Step 1: Click Forget your password? to go to the password reset page.
Step 2: Enter your email address used for registration, and click Send Code.
Step 3: Enter the verification code received, specify the password and then click Save.
After the password is reset, you can use the new password to log into Ruijie JaCS.
