Creating Projects in Batches
1288 / 0
Step 1: Click Dashboard > All Projects > My created to go to the project management page, and then click Import.
Step 2: Click Download Template.
Step 3: Fill in the template.
              (1) Project: (Required) Specify project names. The length of a project name cannot exceeds 256 characters.
              (2) SN: (Optional) Enter the serial numbers of APs.
              (3) Alias: (Optional) Set aliases for projects.
              (4) Room: (Optional) Set a room number where the AP is located. For example: 301. The length is up to 32 characters.
              (5) Building Name: (Optional)  Specify the building name. Up to 32 characters can be entered.
              (6) Remark: (Optional) Enter a remark. Up to 32 characters can be entered.
Step 4: After filling in the template, click Select a XLSX file to upload the template.
Step 5: After the "Succeeded" prompt appears, the batch creation is completed. The created project information will be displayed in the list below.
