Creating a Project Group
2559 / 0
Step 1: Navigate to Dashboard > All Projects > My Created, and then click Project Management.
Step 2: Click Add Management Group.
Step 3: Enter a subgroup name and click OK.
   Note: The length of a subgroup name cannot exceed 256 characters.
Step 4: After creating a project group, select the project group and click Add Project to add a project to the project group.
Step 5: After setting the basic project information, click Save.
           (1) Project Name:  (Required) Set the network name. The length of a project name cannot exceed 256 characters.
           (2) Scenario: (Required) Set a scenario. Defaults: Apartment; Options: Apartment/Hotel/Others (Note: For hotels and other scenarios, you can set the same SSID and password for all devices imported to the project. For apartment scenario, you can set a different SSID and password for each device imported to the project.)
           (3) Time Zone:  (Required) Set a time zone. Defaults: (GMT+9:00)Asia/Tokyo
           (4) Automatic Switching Mode: (Required) Set a working mode. Defaults: Disable;
               Disable: Disabling the automatic switching mode function.
               Bridge: After selecting this option, AP devices imported into the project will automatically switch to bridge mode after they go online for the first time.
               Router: After selecting this option, AP devices imported into the network will automatically switch to routing mode when they go online for the first time.
          (5) Type:  Cloud +AP ( Manage AP devices through the cloud.)
          (6) Location Binding: After binding the geographic location, the number of terminal devices added to the project will be marked and displayed on the Google map.
