Sharing a Project
2366 / 0
Ruijie JaCS supports sharing projects with other tenants for joint management. When the specified sharing period expires, the sharing will be automatically cancelled.
Step 1: Click the share icon  in the Action column of the project to be shared.
Step 2: Set the permission and validity period, and then click OK.
          (1) Permission:
Defaults: Read &Write
Options:
Read & Write: The sharing recipient can view and manage the project.
Read-Only: The sharing recipient can only view the project configuration but cannot manage the project.
          (2) Validity Period after Acception
Defaults: Permanent
Options: Permanent/1 day/1 week/1 month/1 year/Custom. (When you select Custom, you need to specify a concert expiration date. For example, if you set the expiration date to December 31, 2030, the system default validity period is " December 31, 2030 23:59:59 ".)
Step 3: Click Copy to copy the sharing link.
Step 4: Log into the recipient account.
Step 5: After logging in to the recipient account, paste the shared link copied in the step 4 to the address bar of the browser and press Enter.
Step 6: In the pop-up window, click Receive.
              (1) Project: Displays the shared project name.
             (2) Sharer: Displays the tenant account to which the shared project belongs.
             (3) Tenants: Displays the tenant name to which the shared project belongs.
Step 7: After the “The project has been successfully received" prompt appears, the operation is completed.
Step 8: After successfully accepting the shared project, you can switch accounts in the upper right corner of the interface.
            If you don’t want the project to be shared with another tenant, you can click Cancel button on the My Shared page to cancel the sharing.
