Deleting Switches from an Exsiting Project
1426 / 0
To delete switches from a project in batches.
Step 1: Select the switch to be deleted.
Step 2: Click More, and then click Delete.
Step 3: Click OK in the operation confirmation box.
Step 4: After the "Succeeded" prompt appears, the devices are deleted.
In addition to the above deletion method, users can also delete devices one by one through the Delete button in the Action column.
