Ruijie JaCS V2.0
2678 / 0
1. Ruijie JaCS 2.0 provides a brand new UI layout. It consists of three parts: Dashboard, Project, and AI Assistant.
(1) Dashboard: The Dashboard provides three tabs: All Projects, All Devices, and Alarms. In this page, you can check the project list, the information of all devices and alarm information. Also, you can manage projects, project groups, AP configuration templates and upgrade policies.
All Projects: Devices are managed based on projects. Three tabs are available on this page, including My Created, My Received and My Shared. This page provides some basic operations for you to manage projects, such as searching projects by names, sharing projects to another tenant, handing over projects to another tenant and deleting projects. Groups with devices in the Ruijie JaCS 1.0 will be updated to projects in Ruijie JaCS 2.0, while those without devices will remain as groups. Groups serve as the upper layer of projects for logical classification.
All Devices: In this tab, you can view information for all devices across all created projects. Devices can be displayed by type. Also, you can perform operations on this tab, such as upgrading a device, accessing the eWeb of a device, and deleting a device.
Alarms: The alarm function of Ruijie JaCS 2.0 remains the same with that of Ruijie JaCS 1.0.
Project Management: Ruijie JaCS 2.0 supports creating a single project or creating projects in batches.
Group Management: Ruijie JaCS 2.0 supports viewing the group tree and project list created under each group. You can manage both groups and projects.
AP Template Management:In Ruijie JaCS 2.0, the access entry of the AP template management is on the Dashboard page. After navigating to Project > Device Config > AP Template, you can check the AP template that has been applied to the selected project.
Upgrade Policy: The upgrade policy of Ruijie JaCS 2.0 is the almost same as that of Ruijie JaCS 1.0. The only difference is that upgrade policies are applicable only to projects not project groups.
(2) Project: After entering the Project interface, you can manage all devices in a selected project, including checking device topology and device list, configuring devices, etc.
(3) AI Assistant: Ruijie JaCS 2.0 carries an AI assistant, which is used for answering queries related to device information.
2. Ruijie JaCS 2.0 provides an independent management page for ONU devices.
3. Ruijie JaCS 2.0 supports managing Wi-Fi 7 devices RG-MA3511-AC and RG-MA3511-PE. AP templates can be used for configuring devices of these two models. Additionally, you can connect them to Ruijie JaCS via scanning their QR codes.
4. Ruijie JaCS 2.0 supports configuring RG-EG5210-JP via importing configuration files (not require devices to be online), and exporting the configuration file via an IPv6 pathway.
Changes
Ruijie JaCS 1.0 displays the traffic statistics of a first-level group in the Network Report page, while the Ruijie JaCS 2.0 displays the traffic statistics of a selected project.
SSID reverse sync
00000JAPAN Wi-Fi
10
11
TOPOLOGY
12
TOPOLOGY
Included:
XS-S1930J-48GT4SFP
13
14
CLI Commands
15
WPA3-SAE
16
Device Details-Back Up
Only for apartment networks.
17
Network Management
18
Upgrade Policy
19
RG-HS2310-16GH2GT1XS
20
Project
