Accessing the Gateway’s eWeb
2130 / 0
Ruijie JaCS supports accessing the eWeb interface of a gateway through a tunnel.
Step 1: Select the gateway, and click eWeb.
Step 2: Click Create Tunnel. After creating the tunnel, the eWeb interface of the device will automatically open in a new tab.
If the eWEB does not open automatically, you can click "here" to jump to the eWEB or try to re-create the tunnel.
