Ruijie JaCS V1.3.1 Released on August 13, 2021
2158 / 0
New Feature
Note:The following new features are supported in both Apartment Scenario and Non-Apartment Scenario.
  • Support online management of RG-MA2810.
  • Support online upgrade of RG-MA2810
  • Support eWeb management of RG-MA2810
No.Module        Description
1DeviceUp to 300 devices can be imported each time. To import more than 300 devices, users need to do it in batches.
2ConfigurationConfigurations of up to 200 devices can be imported each time. To import configurations of over 200 devices, users need to do it in batches.
3EXCEL templateFor Excel template, only the XLS format is supported.
4SSIDSSIDs can be made up of numbers, English letters, and “-“.
5Custom excel templateIn an Excel customized template, A to Z columns and 1 to 15 rows are supported.
6APAccount-based policies may fail on some models, such as AP680(CD), where they are disabled by default. In this case, users need to batch apply from the Cloud theweb-auth acct-update-interval 1 command to enable those policies.
7SSID reverse syncThe Cloud does not support SSIDs containing special characters. If set on end devices, such SSIDs will fail to be delivered, after synchronization, by the Could.
