Ruijie JaCS V1.4.5.2 Released on December 28, 2022
1937 / 0
This new release supports setting initial configuration templates and device-specific configurations, which are applicable to AP180 series access points in apartment networks. Also, adding networks in batches is available now.
  • In this new release, after specifying the parameters and clicking Save to add an initial configuration template, you can click Edit to configure the details of the template.
  • In this new release, you can add networks in batches.
  • In this new release, you can click MANITENANCE > Config Log > Device View to check the configuration logs of the initial configuration templates.
You also can click  in the Action column to check the status of an initial configuration template.
No.Bug Description
1MA2810 V1: No record existed in the Client List on JaCS when a mobile phone went offline.
2The number of terminals connected to a network was shown as 0 even if the terminals were connected.
SSID reverse sync
00000JAPAN Wi-Fi
10
11
TOPOLOGY
  2. Only access points (excluding MA series access points) and switches can be displayed in the Topology.
12
TOPOLOGY
Included:
XS-S1930J-48GT4SFP
13
