Ruijie JaCS V1.4.5 Released on October 25, 2022
2500 / 0
  • Initial Configuration Template
(1) In the new release, you can apply an initial configuration template to all AP180 series devices in an Apartment network.\
(2) If an initial configuration template has been applied to the device, Yes will be shown in the initialized column in the AP List.
(3) When adding or editing an Apartment network, you can decide whether to apply an initial configuration template to all AP 180 series devices in the network when they are connected to the JaCS for the first time. It should be noticed that the configurations are automatically applied to the devices once only.
  • Device-specific Configuration
In the new release, you can use the provided template to set specific configurations for devices. Up to 200 templates are supported.
  • Displaying a Supported RF
In the new release, the supported RF of a device will be displayed when you hover the mouse over the SN of a device.
  • Setting Log
In the new release, you can click MAINTENANCE > LOGS > Settings Log to check the device-specific configuration logs.
  • Intelligent Physical Link Detection
In the new release, a Detect button for link detection is added in the pop-up window in the Topology page. You can click it to detect the status of a physical link. Three detection results may occur, including normal link, link failure and no link.
After completing the operation, you can click MAINTENANCE > LOGS > Operation Log to check the log.
No.Bug Description
1MA2810 V1: No record existed in the Client List on JaCS when a mobile phone went offline.
2If Web CLI permission is enabled for an existing admin account, the permission of account can not be disabled.
3In the Hotel scenario, CLI commands with slashes (/) and periods (.) were not allowed to be entered in the Advanced Settings in the Basic setting page.
4Some sub accounts, such as admin, employee and guest, could not use Web CLI to check fixed commands.
APAccount-based policies may fail on some models, such as AP680(CD), where they are disabled by default. In this case, users need to batch apply from the Cloud the web-auth acct-update-interval 1 command to enable those policies.
SSID reverse sync
00000JAPAN Wi-Fi
AP180 before bring them online; otherwise, the configuration on devices may be conflict with that on Cloud, and the client may not be able to access the Internet.
10
In Non-apartment Scenario, if the working mode (bridge mode or routing mode)
of AP180 is different from that on Cloud, the client may not be able to access the Internet.
11
TOPOLOGY
  2. Only access points (excluding MA series access points) and switches can be displayed in the Topology.
12
TOPOLOGY
Included:
XS-S1930J-48GT4SFP
13
Initial Configuration TemplateThe template can only be applied to AP180 series access points in Apartment networks.
