Ruijie JaCS V1.4.2 Released on April 1, 2022
2439 / 0
  • Add the threshold alarm for CPU, memory and channel usage.
  • Support custom role management.
 (1) Add a custom role.
(2) Edit a custom role.
Customize the role for the sub account.
  • Support configuring the access policy.
(1) Add an access policy.
(2) Edit an access policy.
(3) Bind the access policy to a sub account.
After the S1930 switch goes online, CLI will print the error message: /sbin/maccmng.sh: line 1: arithmetic syntax error
If Web CLI permission is enabled for an existing admin account, the permission of account cannot be disabled.
When the SSID named “00000JAPAN” is imported, the prompt is improper.
When a rule is imported to an apartment network, two prompts will be displayed if the position is repeated.
Up to 300 devices can be imported each time. To import more than 300 devices, users need to do it in batches.
SSID reverse sync
00000JAPAN Wi-Fi
In Non-apartment Scenario, please clear the configuration on devices except AP180 before bring them online; otherwise, the configuration on devices may be conflict with that on Cloud, and the client may not be able to access the Internet.
10
