Ruijie JaCS V1.3.2 Released on September 17, 2021
1992 / 0
  • PoE configuration
  • Add the schedule policy for PoE
  • Add the auto checking of PoE configuration
  • Add the PoE status monitoring
  • 00000JAPAN WiFi
Support one-click enabling/disabling 00000JAPAN on devices of layer-1 network (including its sub networks)
  • Improve JaCS UI
(1) Login
(2) Register
(3) Forgot password
(4) Navigation bar
  • Add the permission whether to allow the sub accounts to check Web CLI
In the Sub Account List, you can configure whether the sub account can check Web CLI
  • At most 6000 devices can be added to a layer-1 network and its sub network.
  • Cloud management of MA2610
(1) Bring the device online
(2) Upgrade the device
(3) eWeb system
Up to 300 devices can be imported each time. To import more than 300 devices, users need to do it in batches.
SSID reverse sync
00000JAPAN Wi-Fi
In Non-apartment Scenario, please clear the configuration on devices except AP180 before bring them online; otherwise, the configuration on devices may be conflict with that on Cloud, and the client may not be able to access the Internet.
10
