Ruijie JaCS V1.2.2 Released on July 25, 2021
1861 / 0
  1. The Config Log of SSID/password can be exported into the XLSX file.
Up to 300 devices can be imported each time. To import more than 300 devices, users need to do it in batches.
APAccount-based policies may fail on some models, such as AP680(CD), where they are disabled by default. In this case, users need to batch apply from the Cloud the web-auth acct-update-interval 1 command to enable those policies.
SSID reverse sync
The Cloud does not support SSIDs containing special characters. If set on end devices, such SSIDs would fail to be delivered, after synchronization, by the Could.
