Ruijie JaCS V1.1.3 Released on May 15th, 2021
2086 / 0
  • Add the switch’s PoE functions including the PoE power supply policy, PoE auto-check policy, PoE control policy and PoE summary display. (Beta release)
  • Export the report into a PDF file.
  • Add devices on NETWORKS.
  • Jump to configuration on NETWORKS.
  • Configuration synchronization functions:
  1. Synchronize the configuration files from the AP device to Ruijie Cloud automatically.
  2. Display the backup of configuration files.
  3. Back up, restore, delete and display the current configuration files manually.
  • Manually synchronize the SSIDs and passwords of the devices to Ruijie Cloud.
Up to 200 devices can be imported each time. To import more than 200 devices, users need to do it in batches.
SSID reverse sync
The Cloud does not support SSIDs containing special characters. If such SSIDs are set on end devices, the Cloud would fail to deliver them after they are synchronized to the Cloud.
