Ruijie JaCS V1.0 Released on November 25, 2020
1881 / 0
  • Support apartment scenario
  • Support AP108 change device mode between bridge mode and Router mode.
  • Support custom EXCEL parse rule for add device and import device SSID and password configuration.
  • Support extended device information fields.
  • Support scenario SSID and password configuration.
  • Support AE1021 devices monitoring.
  • Support AE1021 SSID and password configuration.
  • Support AE1021 IP segment manager and white list switch.
  • Support SSID and password configuration log manager and export configuration result.
  • Support agent system for AE1021 management (PC local agent system and cloud agent system).
Details
deviceOne time can only import up to 200 unit devicesImport devices, each time can only import 200 units, more than 200 units to import in batches
configurationOne time can only import up to 200 unit devices configuration.Import devices configuration. Can only import the configuration of 200 devices at a time, more than 200 units devices configuration to import  in batches
AE1021Can only manage 8000 AE1021 devices at mostFor AE1021 devices, a network can only manage 1000 devices, and the whole agent system can manage 8000 devices at most
EXCEL templateCan only support XLS Excel templateExcel template format only supports XLS format, other formats do not support.
SSIDSSID value limitationSSID supports numbers and English characters, while special characters only support “-“.
Custom excel templateExcel custom template ruleExcel customized template, the number of columns supports A ~ Z, the number of rows supports 1 ~ 9.
AE1021AE1021 goes online timeIt takes about 7-10 minutes for AE1021 goes online from IP management.
AE1021IP manage limitationIf a customer adds a 1021 device, sets a static IP address, and manages the handoff whitelist, and then deletes the 1021 device and relocates the 1021 device (if it does not remember the IP and does not fill in the IP manually), the device will not be able to go online. Because the whitelist has been switched, the agent system tested by the customer can no longer manage the device or reset the IP address Equipment to restore factory settings to solve.
networkLength of network name limitationOnly support up to 32 characters.
