Ruijie JaCS V1.0.1 Released on December 15, 2020
1986 / 0
  • Network name support up to 64 characters.
  • Import AP180 and AE1021 device SSID and Password together at one time, configuration log and export result will be together.
  • Update Configuration log export EXCEL result data format.
(1)If the format of the building name is “xxx_yyy”, the building name will be “yyy” in exported EXCEL file.
(2)Date format is “yyyy MM/dd hh:mm”.
Details
device
One time can only import up to 200 unit devicesImport devices, each time can only import 200 units, more than 200 units to import in batches
configuration
One time can only import up to 200 unit devices configuration.Import devices configuration. Can only import the configuration of 200 devices at a time, more than 200 units devices configuration to import  in batches
AE1021
Can only manage 8000 AE1021 devices at mostFor AE1021 devices, a network can only manage 1000 devices, and the whole agent system can manage 8000 devices at most
Can only support XLS Excel templateExcel template format only supports XLS format, other formats do not support.
SSID value limitationSSID supports numbers and English characters, while special characters only support “-“.
Excel custom template ruleExcel customized template, the number of columns supports A ~ Z, the number of rows supports 1 ~ 9.
AE1021
AE1021 goes online timeIt takes about 7-10 minutes for AE1021 goes online from IP management.
AE1021
IP manage limitationIf a customer adds a 1021 device, sets a static IP address, and manages the handoff whitelist, and then deletes the 1021 device and relocates the 1021 device (if it does not remember the IP and does not fill in the IP manually), the device will not be able to go online. Because the whitelist has been switched, the agent system tested by the customer can no longer manage the device or reset the IP address Equipment to restore factory settings to solve.
network
Search boxIf the network name length is more than the width of the search box, then move mouse on the network name (the network name is selecting status), part of the network name that exceeds the width of the search box will not be displayed.
