Ruijie JaCS V1.1.2 Released on April 15, 2021
3013 / 0
Note: The following new features are supported in both Apartment Scenario and Non-Apartment Scenario.
  • Register and Login
  1. Register
2. Forgot Password
  • Authentication
1. SSID Apply Captive Portal
2. Voucher
3. Account
4. PPSK
5. Captive Portal
  • Optimize Auto Switch AP mode
Up to 200 devices can be imported each time. To import more than 200 devices, users need to do it in batches.
For the Excel template, only the XLS format is supported.
In an Excel template for customization, A to Z columns and 1 to 15 rows are supported.
APAccount-based policies may fail on some models, such as AP680(CD), where they are disabled by default. In this case, users need to batch apply from the Cloud the web-auth acct-update-interval 1 command to enable thoese policies.
