Ruijie JaCS V1.1.0 Released on February 28, 2021
4536 / 0
  • Apartment scenario
1. Support common apartment scenario.
2. Apartment scenario, “Import Config”, SSID and Password can’t be empty.
3. Apartment scenario, only reserve jump to configuration log of “Import Config” and “Auto SSID Config”.
  • Non-apartment scenario
  1. Withdraw feature “CONFIGURATION->WIRELESS->Load Balance”.
2. Default country code to “JP”, default time zone to “(GMT+9:00)Asia/Tokyo”
  • Both apartment and non-apartment scenario
  1. Default time zone to “(GMT+9:00)Asia/Tokyo”
Details
DeviceCan’t edit device description.In device list, can’t edit device description.
ConfigurationCan’t auto refresh device configuration list.Through “Auto SSID Config” to configure device SSID and password. Can’t auto refresh device configuration list.
Configure logSearch configuration log wrong.Through time rang to search configuration log, the search result is incorrect.
Device Device search doesn’t match upThe device search rule doesn’t match up.
ModuleDescriptionDetails
deviceOne time can only import up to 200 unit devicesImport devices, each time can only import 200 units, more than 200 units to import in batches
configurationOne time can only import up to 200 unit devices configuration.Import devices configuration. Can only import the configuration of 200 devices at a time, more than 200 units devices configuration to import  in batches
EXCEL templateCan only support XLS Excel templateExcel template format only supports XLS format, other formats do not support.
SSIDSSID value limitationSSID supports numbers and English characters, while special characters only support “-“.
Custom excel templateExcel custom template ruleExcel customized template, the number of columns supports A ~ Z, the number of rows supports 1 ~ 15.
