Ruijie JaCS V1.0.3 Released on January 14, 2021
4651 / 0
  • End SSID and password configuration of offline device immediately
Suppose the operator modifies the SSID and password of two rooms and exports excel.
Although there are offline devices waiting for SSID and password configuration, the overall status is complete. The operator can export excel and send new SSIDs passwords to the tenant. When the offline devices go online, the new SSIDs and passwords will sync to the devices automatically.
  • Apartment scenario, jump to configuration log, display the last SSID and password setting log by default.
Details
NetworkCan’t switch to default networkCan’t Switch to default network through “All” network when the current menu don’t support “All” network.
DeviceThe configuration logs are separated.The configuration logs are separated when add device through EXCEL with SSID and password.
Configure logExport SSID and password wrongWhen unfold 2 or more configuration logs, export configuration log is not the SSID and password setting log.
Device Add device failedWhen add devices through EXCEL with EXCEL parse role. Can’t add devices.
Details
deviceOne time can only import up to 200 unit devicesImport devices, each time can only import 200 units, more than 200 units to import in batches
configurationOne time can only import up to 200 unit devices configuration.Import devices configuration. Can only import the configuration of 200 devices at a time, more than 200 units devices configuration to import  in batches
AE1021Can only manage 8000 AE1021 devices at mostFor AE1021 devices, a network can only manage 1000 devices, and the whole agent system can manage 8000 devices at most
EXCEL templateCan only support XLS Excel templateExcel template format only supports XLS format, other formats do not support.
SSIDSSID value limitationSSID supports numbers and English characters, while special characters only support “-“.
Custom excel templateExcel custom template ruleExcel customized template, the number of columns supports A ~ Z, the number of rows supports 1 ~ 15.
AE1021AE1021 goes online timeIt takes about 7-10 minutes for AE1021 goes online from IP management.
AE1021IP manage limitationIf a customer adds a 1021 device, sets a static IP address, and manages the handoff whitelist, and then deletes the 1021 device and relocates the 1021 device (if it does not remember the IP and does not fill in the IP manually), the device will not be able to go online. Because the whitelist has been switched, the agent system tested by the customer can no longer manage the device or reset the IP address Equipment to restore factory settings to solve.
